  1. Member Hal05154's Avatar
    Apr 2007
    Well, THAT didn't go exactly like I hoped...
    Hi Folks,
    I was using TMPGEnc 4.0 XPress & DVD Author to work up some tv shows I wanted to put on dvd. Everything was going great. I used XPress to convert several shows to one big file with a decent bitrate, and then used DVD author to chop up the chapters. Then came to problem, and where I need advice.
    I cannot figure out how to make a menu that shows all my shows individually. Xpress is only looking at my movie as one BIG movie, rather than 6 separate shows. I went through and set chapter breaks, I even labeled them, but I can't get the menu to display this.
    Am I making sense? I sure hope so. If someone could please help, I'd appreciate it.
    Have a great day!
    Hal
    I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone.
  2. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    You need to put different shows to different tracks (by selecting 'add new track' each time) at authoring. Import your file 6 times and trim it on timeline for each track. Then you'll be able to have top menu + menu pages for each show linked from top menu.
