I am trying to convert an AVI to DVD. The DVD conversion has worked, but the audio is about 1-2 seconds out of sync with the video. Anybody else run into this??
Sync problems are extremely common (do a search on this forum for proof). Many causes, few fixes.
If the source file has errors (very common if the original source was analog, such as from a broadcast medium or VHS tape), you'll need to fix those errors to perform a "real" fix.
Another possibility is to try transcoding using the "decode with QT" option, if you haven't already tried that. QT sometimes maintains sync somewhat better.
Absent that, here are some alternatives:
If the sync error is a simple offset (i.e., the error is a fixed amount of time), then use something like vlc to determine the offset, and then remux your stream to compensate.
If the error drifts at a constant rate, then you can use a tool such as Audacity to lengthen or shorten the audio track to compensate.
If the error jumps, you can slice up your clip into pieces within which the errors are constant, fix each separately and splice the fixed segments back together (yes, this is a pain).
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
AVI's audio out-of-sync
By Madgelina in forum AudioReplies: 5Last Post: 1st Jul 2007, 21:00
