I do a lot of CD and DVD burning, though the latter are as often assemblages of transcoded AVI files as they are properly formatted DVDs. I've had good luck in recent years with low-cost standalone boxes from Pioneer and Phillips being able to play a wide range of file types, but now that I need a replacement unit, I don't know what the current models are that can play (a) 5.1 surround-encoded discs, (b) DTS-encoded discs, and (c) AVI files that have not been transcoded to DiVX or XViD. If I had to choose among capabilities, I'd go for the 5.1/DTS capability, and just go through the AVI transcoding process when I need to. (Most of the AVIs I acquire do need transcoding anyway, so that won't be a huge sacrifice...)
Would like to keep this under $200, but whatever...
tnx, BB
	You can perform a search in the DVD Players section. Most players now support DD5.1 and DTS, so you will mainly be searching for a Divx player. You can get a list of Divx certified players at Divx.com.
 Take a look at the Oppo players. Excellent video quality and very good Divx support. http://oppodigital.com/Google is your Friend
  Playing old AVIs on new DVD playerBy tandanus in forum Newbie / General discussionsReplies: 4Last Post: 28th Aug 2011, 19:50
  Tool similar to TMPGEnc DVDAuthor that can handle DTS audioBy robertazimmerman in forum Authoring (DVD)Replies: 6Last Post: 12th Jan 2011, 12:45
  Looking for BD Player that can handle video from USB/HD, and NetFlix.By Huh...What? in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Jul 2010, 12:28
  Does the wdtv media player handle dvd pal iso files?By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 12th Dec 2009, 13:34
  Problem playing certain AVIs on standaloneBy max6166 in forum Newbie / General discussionsReplies: 12Last Post: 20th Dec 2008, 23:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
