    Nov 2007
    My friend asked that I post this since his internet is off.
    I am running Final Cut 4.5 HD on a MAC G5. The computers drive has about 49 gigs of free space, but I capture all my footage on external drives anyway for more space. The computer has 4 gigs of memory. the maximum it can have. Recently, when I capture footage, it goes for about 5 minutes and then freezes up each time I try to capture. I have to force quit. It puts a huge file on my ext. drive which is unreadable. I dump it immediately because it almost fills my entire drive. I have tried using 3 different ext. drives and it still happens. I dumped and re-installed my Final Cut and it still happened. All the other Final Cut functions are working. Only the logging is where I have trouble. It seems like it is a computer problem, not software. Everything else on the computer is functioning normally. I also ran a [verify disc] proceedure and [restore permissions]. It said that the drive checks out okay. The problem still occurs. Any ideas what it could be?
    Thankyou
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Capture to an internal drive then copy the file to the external drive. Best if the internal drive is defragged first and is not the same drive with the OS.
    If you don't have space on the internal drive, move your junk to the external drive then defrag the internal drive.
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    James,
    has your friend ran FCP Rescue?
    FCP Rescue will fix the permissions in FCP,
    that disc Utility will not fix, as it looks
    primarily at the System Prefs and frameworks.
    FCP writes its own firewire and quicktime preferences
    related to capture and scratch drives. FCP Rescue
    repairs or replaces them from a good backup.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Nov 2007
    I'll run that past him, thanks for your help.
    Nov 2007
    He was wondering where he would get that FCP Rescue?
  6. Member terryj's Avatar
    see link my post.
    (click on the "FCP Rescue" in my question)
    Urban Mac User
