How do I capture video through a Pinnacle 700-USB without using Pinnacle Studio.xx. I want to keep Pinnacle Studio as far as possible from my computer!
I tried some programs like iZE TV, Stoik Video Capture and AVI IO, but so far I had no luck.
Have you tried VirtualVCR, HUFFYUV, VIRTUALDUB...
What is the problem with using Pinnacle. While I'm not a big fan of Pinnacle, if it works for you and isn't buggy, it is a good program. If the capture portion works, use Pinnacle for just that portion, then use other progs for the rest.Rob
how to connect an old camcorder to USB capture device
By deanno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2009, 13:40 -
How would you all rate this japanese USB capture device ?
By MidnightMike in forum Capturing and VCRReplies: 12Last Post: 20th Jul 2009, 22:29 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 02:23 -
capture device: usb or pci?
By danica in forum Capturing and VCRReplies: 2Last Post: 5th Sep 2007, 12:04 -
USB Capture Device
By gruberted in forum Capturing and VCRReplies: 13Last Post: 11th Jul 2007, 13:56
