2 questions if i may:
question one
i have xp machine with 20 Gb drive split in two.
xp on c: and a disc image of c: created with xxclone on d:
i have decided to dump the xxclone image and use the disc space.
having formatted the d: drive, the boot up procedure stills reports and requests a choice of disc to boot from at the bios, the regular c: windows or the d: backup.
here is my boot ini, what should i alter it to to remove the dual boot option
[boot loader]
timeout=01
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect /NoExecute=OptIn
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="XXCLO NE: (Cloned Volume) [d:0,p:2] \WINDOWS" /fastdetect /NoExecute=OptIn
question two
i have a ethernet network setup between two other seperate offline xp machines: wired together with a crossover cable, no routers no nuthin, just two machines and and two ethernet cards. no internet, no nothing.
if i access the movie folder on the d: drive of machine A and check its properties it comes up as 76.9Gb with 180 files, ntfs, all present and correct.
if i access the same folder from the network machine it reports the same folder as 8.62Gb and 29 files, and only display 29 of the files.
whats that all about?
any light you can shed would be most gratefully absorbed.
wishing you a pleasant evening/day/afternoon/
1. leave it alone because it is you backup drive to boot from if C: will not boot.
But if you really want to, delete
2. check the NTFS and Sharing permissions on the computer that holds the data, sounds like some of the files are "owned" by a user account that is not on the remote PC -
i want to get rid of it, the drive is empty, just the boot ini info is left behind.
thankyou for that.
there are no accounts set up on the machine 'A' so i dont know if that is the case, but thanks for the reply. -
Question 1 is answered. Question 2 sounds like you may have the folder view options set differently on the two machines. Machine A displays all files, including Hidden or System files. Machine B hides Hidden and/or System files. Might not be it, since I can't imagine why any videos would be hidden or system, but it's worth checking.
Buy My Books -
Good catchOriginally Posted by gadgetguy
I always seem to go for the security side and forget the obvious
DVD Rebuilder .ini file
By wulf109 in forum DVD RippingReplies: 1Last Post: 12th Feb 2010, 13:34 -
Using Blueray player ethernet port to play video from home network storage
By gbvideo in forum DVD & Blu-ray PlayersReplies: 10Last Post: 2nd Jan 2010, 12:33 -
BOOT.INI file
By CSULB71 in forum ComputerReplies: 11Last Post: 26th Dec 2009, 11:19 -
CDplayer.ini Question
By hech54 in forum ComputerReplies: 8Last Post: 11th Sep 2009, 13:57 -
boot.ini need back
By intensive in forum ComputerReplies: 3Last Post: 17th May 2007, 09:49
