I have tried the Virtualdub 'Append AVI Segment' method which doesnt work for different sampling rates.
So my only other option is to extract the audio and join the video and audio files separately which seems very time consuming for what should be a simple process of joining 2 files together. Is there a program that ill do it in one go even with different sampling rates?
AVI doesn't allow for changes in audio sampling rates in the middle of the file. One will have to be converted. It's easy to do in VirtualDub:
File -> Open Video File
Video -> Direct Stream Copy
Audio -> Full Processing Mode
Audio -> Convert -- select proper settings
Audio -> Compression -- set same codec and settings as other file
File -> Save as AVI
It'll probably take 5 to 10 minutes to recompress the audio. -
Sorry, but that didnt seem to work.
You lost me after :
Audio -> Full Processing Mode (R click on the audio, select 'Full processing mode'.)
Audio -> Convert -- select proper settings (You probably just need to change the sampling rate to the same as the other file. If the format is different, you will need to use 'Compression' instead.)
Audio -> Compression -- set same codec and settings as other file (If the audio file is MP3, then you may want to add the Lame MP3 ACM codec as it will give you more settings than the default one.)
File -> Save as AVI
In VD if you go to 'File>File information', you should see the attributes of the audio and video, including the sample rate, etc., for comparing the two files. You can also do this with Gspot 2.70. -
You probably figured it out, but rather than Audio -> Convert, it's Audio -> Conversion. Sorry.
If you're using VirtualDubMod the audio handling is a little different. Use the Streams menu and select Stream List. Right click on the audio stream to get the Audio options.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 07:46 -
Simplest way to join 15 avi's into 1
By macbuz in forum MacReplies: 3Last Post: 20th Jan 2009, 17:06 -
The audio streams have different sampling rates, blah blah
By Kobong in forum EditingReplies: 5Last Post: 8th Jul 2008, 07:07 -
Simplest way to convert and join avi's with different audio streams??
By Lolipop Jones in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2008, 12:25 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09
