This worked for me using the latest version of DVDFAB,DVDShrink and CloneDVD.
1. Rip movie to hard drive using DVDFAB
2. Open DVDshrink . Instead of clicking 'open disk', click 'open file'.
3. Open the dvdfab file that you saved to your hard drive
4. Click 'Backup' and make sure you DISABLE video preview
5. Save the new backup to your desktop under a NEW name
6. Open 'CloneDVD' and click 'Write Existing Data'.
7. Click the NEW file on your desktop.
8. Burn and Voila
9. Hope this helps to those who were stuck like me.
Any question, PM me
[/b]
Results 1 to 30 of 40
Video Preview in Shrink should have no influence on the success or otherwise of the process.
What does CloneDVD add to the proceeding if Shrink has already processed (successfully) the file ?
I suspect that more than anything it was a matter of waiting for a suitable version of DVDFab Decrypter to be released.Read my blog here.
I tried using RipIt4Me and DVD Decrypter/DVD Shrink and it did everything fine (including analysis) and was burning the disk. However, I woke up this morning and it said the DVD burning/write failed.
Not sure what I did wrong? RipIt4Me was 1.7.1.0 and DVD Shrink was like 3.2. Is there a certain setting or thing I'm supposed to change? I pretty much followed what RipIt4Me told me to do...
I think I have an old version of CloneDVD and DVD Decrypter is probably old too. I don't have DVDFab but if that's free I guess I could download it. Not sure what I did wrong above though I think I had the video preview disabled as well. -
DVD Decrypter does not work on RATATOUILLE. It will attempt to rip the disc and then fail. DVDShrink has the same problem. AnyDVD will sucessfully rip the disc. Then use CloneDVD to burn.
Not sure if it was necessary but - used CloneDVD to create an ISO of the AnyDVD rip, the used CloneDVD to burn the ISO.
Using AnyDVD with DVD Decrypter does not work either. With AnyDVD running you will be able to rip with DVD Decrypter. However, when you go to burn the ISO (created with DVD Decrypter) with ImgBurn, ImgBurn will produce an error saying the layer break is missing. You can continue and burn the DVD. This was not tested since dual layer discs are pricey. Hence the AnyDVD to CloneDVD route.
Once a disc as been burned via AnyDVD to CloneDVD solution, DVD Decrypter can be used on that disc successfully. -
Originally Posted by RLT69
but i just read in other posts and on other forums that AnyDVD didn't work. I have AnyDVD and CloneDVD I believe but they are probably older versions. I used RipIt4Me and it successfully ripped with Decrypter and Shrink and just had a writing problem. Maybe if I do the same thing but do just the main movie it would work?
I just want to do it the easiest way and it seems like people are all using several different programs all with different levels of success. -
is there somewhere to download those programs? my versions are probably a year old. or are they not freeware?
You can download trial versions of the software from their site. I believe the trial period is 21 days.
http://www.slysoft.com/en/download.html?aid=50081 -
Use the latest version of DVDFabDecrypter (free). RipIt4Me is no longer being updated.Originally Posted by 5.9LITRE
A clean rip is only one problem with this title. Among other things it defaults to 2.0 audio. It can also take an eternity to load unless you bypass the forced previews. The menus are cloned so you have to blank the same unused buttons over and over again, then find the highlight commands which point to them and change the values
I finally got it to work but the audio was to 2.0.
For what it's worth - I've had the best luck with DVDDecrypter up until Ratatouille .. hopefully that'll get updated.
(btw...this is my first post. This is a great forum!!)
Provided you haven't deleted anything, you can visit the setup screen and and select 5.1 audio from there. I changed one of the pre-commands so that 5.1 audio is auto-highlighted instead of 2.0 but I don't remember which one it was? I think it was Line 4 in "VTSM 6, LU 1 (en) 24 0.36 7b" which now reads: "LinkCN Cell 1, button 1 (1024)".Originally Posted by ExpensiveWino
That was one of the simpler jobs with this particular title. If for example you strip the 2.0 audio altogether in order to preserve picture quality there is a good chance the audio won't play at all. In my opinion none of the extras are worth preserving except the "Your Friend The Rat" featurette. -
bandit33usa>>>
"I just got done copying it a little easier.
Used AnyDVD to rip it to my computer
Then used Shrink to work its magic(as usual)...done
Result - Perfect working copy"
What media did you use? I'm up to about 9 coffee coasters using about 5 different program combinations, and I'm starting to think it might be my media (Memorex, TDK, FujiFilm & Verbatim all 4.7Gb DVD - R). Some of the burns will play on my computer, but don't play on my home DVD player which is a first. I'm currently trying AnyDVD RIP/ CloneDVD2 Write. Maybe this will work. -
Nevermind, got it to work with AnyDvd/Clone2DVD combo. Thanks for all the info.
RATATOUILLE will rip with Ripit4me1710/DVDDecryptor/DVDShrink in movie only mode.
Recipe for another perfect RATATOUILLE burning:
INGREDIENTS
Decrypter: DVDFab HD Decrypter 3.2.1.0 Free Edition
Burning Soft: Elby CloneDVD2 2.9.0.3
Burning Hard: HL-DT-ST DVD-RAM GSA-H55N (rev. 1.02) (LG MODEL GSA-H55N With Extra Ivory bezel Included!!!)
DVD used: Matrix DVD+R DL 8X 8.5GB/240MIN
Sys OP: Windows ME 4.90.3000
IE: Internet Explorer 6.0.2800.1106 SP1 (Dunno what for but might help)
CPU: Celeron 900
Memory: 640 MB
Popcorn: ACT II Extra Butter (3 packs for 5 people)
Refreshment: Assorted(Beer, Coke, Orange Juice, Milk...) (MILK WITH POPCORN!?!?!?!?!?!?!?!?!? YUCKS!!!!!!)
PROCEDURE:
Decrypt with DVDFab. Insert DVD Matrix into LG DVD Burner. Burn with CloneDVD2. ENJOY!!! -
You can offer help, but you can't make them listen.Originally Posted by guns1inger
Believing yourself to be secure only takes one cracker to dispel your belief. -
I can successfully rip this to my system fine, but DVD Shrink hates it without turning off the preview and DVD Rebuilder fails during the rebuild phase.
I've tried manually tweaking this in DVDRemake, but with little success.
Has anyone managed to build a full DVD re-encoded with DVD Rebuilder?
Even with the updated decrypters there's still something not quite right about these DVDs. -
Yeah yeah, it shrinks fine with the preview disabled, but they've intentionally corrupted the disc.
I'm curious if it can actually be fixed.
Anyone make a DVD5 with re-encoding software and not some Shrink type program?
Ratatouille, still - please don't hit me
By berger in forum DVD RippingReplies: 2Last Post: 19th Dec 2007, 15:58 -
RATATOUILLE no workie worky
By studpuppy in forum DVD RippingReplies: 5Last Post: 6th Dec 2007, 22:46 -
i cannot burn or decrypt disney movie Ratatouille
By studpuppy in forum DVD RippingReplies: 33Last Post: 3rd Dec 2007, 17:29 -
Ratatouille gives up after 10% in DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 2nd Dec 2007, 08:47 -
can't decrypt Ratatouille!
By studpuppy in forum DVD RippingReplies: 1Last Post: 25th Oct 2007, 21:45
[/b]
