Results 1 to 20 of 20
  1. Ive been using this program for awhile and have had no problems. Well it keeps messing up on this one file. The file is NTSC MSMPEG4 at 720x480. After the conversion I end up with one VOB at 600Megs. Playback is just a green screen and with the sound that is suposed to be there.
    Any sugestions?
    -Del
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Far back in history, I had that green screen phenomenon with all my XviDs I tried to reencode. It's a codec related problem, and for me, the cure was to change the fourCC to DX50 instead of XVID.
    /Mats
  3. I have not had any issues with my other Xvids but eventualy you will run across a trouble one. So How do I make the change? Some kind of program to use?
    thanks
    -Del
  4. Forgot to mention. that when playing the original file on the computer it plays fine. Only the files created from svcd2dvd playback with a green screen.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Then it might be something else. Chris? Are you listening?
    /Mats
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Yes - i am listening, but have never seen this before.... Can you post the relevent log for this issue and we'll take it from there.
  7. Tell me wht log you need and it shall be posted. I did not make the final DVD. I test them in windows before I make a coster. Here is another strange thing. When adding to aset the space bar goes red at the end. I hit auto fit and it takes it down to DVD-5 with no issue but only puts out 1 600meg VOB file instead of the usual 4 1gig vob files and a vob with the excess.
    -del
  8. If you are using the latest version, the logs are under the help button. Post the log for the run that gave you the green video. Older versions (older than 2.5) have the logs in the "logs" folder in the S2D install folder
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  9. Ok I found the file but am having trouble uploading it. Is there an email I can send it to? The file is 8.7 megs. Don't know why it is that big.
    -Del
  10. ChrissyBoy's email is in his profile.
    Dwight
    - Herm Albright
  11. Ok got the E-mail and sent the log. now I sit and wait
  12. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Did you zip it? 8MB is too big otherwise.
  13. Ok zipped the file up . here goes nothing
    -Del
    svcd2dvdlog.zip
  14. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    There are tons of "pixel format conversion not handled" errors from ffmpeg which i suspect is the issue. Maybe an update to the latest version of SVCD2DVD will resolve this...
  15. I installed the newest SVCD2DVD. The result is both the same and different. I still get a green screen on the output files but the file size is now 80megs. I guess this avi just does not want to be converted. Unless Chrissy boy wants to continue to try and troubleshoot this file I will call it a lost cause and give up on it. Can't expect every file to work I guess. 1 out of how many 100 is not bad at all. I will just move on and keep converting other files. Great program.
    -Del
  16. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I concur - it looks like the program is choking on that one file... Sorry about that...
    Dec 2007
    Canada
    I have a problem converting .ts files with version 3.5.3500 (downloaded Nov. 24th).
    - I have a 7GB .ts file
    - I load the file into the assets window and the time stamp shows up with some crazy negative number like -1.07
    - I push the "autofit" button
    - The resulting MPG is way below 4GB, around 1.5G and the image quality is very poor when the output files in the video folder are all burned to DVD.
    I tried breaking the 7G file in to smaller pieces and loading independently as 2,3 and 4 parts, but always one of the parts has that crazy negative number for time duration.
    Am I doing something wrong? Is this a bug?
  18. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    May i suggest you run the file through VideoReDo's QuickStream Fix to sort out the dodgy timestamps in the file? It should take a few minutes and then you should be able to use the file with no issues.
    Dec 2007
    Canada
    That fixed it. Thanks. VideoRedo is only a 15 day trial without buying it. I'm not super-excited about having to buy another application. Is there any freeware that does the same thing?
