I have an input video with a AR of 2.35:1 that I'd like to convert to 1.77:1 (or 1.85:1).
The original file's resolution is 640x272; and I'd like to convert it to a resolution of 312x176 to put on my iPod Touch.
I am using AviSynth to resize the video before encoding and this works fine, however, I want to be able to downsize the video to achieve a 1.77:1 AR without having a distorted AR.
The reason I want to convert it to 1.77:1 is because that way I can get more video with less black bars on the IPT's screen.
Is the only way to properly resize to crop off parts of the video from the sides or is there another way of accomplishing this?
Also, would someone please post the proper way of accomplishing this in AviSynth, what I came up with I can't reproduce right now and I'm not even sure if it's right.
Thanks.
Hi-
Yes, it's the only way to accomplish it at the same time keeping the proper AR.Is the only way to properly resize to crop off parts of the video from the sides or is there another way of accomplishing this?
Crop(78,0,-78,0)
LanczosResize(312,176)
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 20:45 -
Exactly what goes on in conversion?
By Haopengyou in forum Capturing and VCRReplies: 1Last Post: 2nd May 2011, 10:52 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 10:46
