Hi, I have downloaded clips I get from a website, and they are in .divx format,
PLEASE let me know if there is a software program that will let me convert these
files to .avi
Any help would be very much appreciated, thank you!
Results 1 to 9 of 9
Hi-
They should already be AVI. Just rename the extension as .avi. If there's any chapter information in there, you'll lose it, but who cares? -
Open the file in virtualdub, then do a direct stream copy to put it into an avi container.
Read my blog here.
Won't players usually just ignore the Ultra features of the video, though (assuming they don't support DivX 6/Ultra features)? If that's the case, streaming into a new AVI when it already is an AVI might just be an extra step.
If cameras add ten pounds, why would people want to eat them? -
You may have problems with .divx files with menus and multiple titles. Renaming to .avi may only allow a player to see the first title. Remuxing with VirtualDub has the same problem.
My brother has a couple of players that won't see files with the .divx extension, but handle them happily after a run through virtualdub, however these don't have any ultra features.
Read my blog here.
Thanks guys for the suggestions, I've tried virtualdub and it crashes,
I've also tried changing the extension to .avi and no luck, even tried
re-encoding it and burning file to dvd with adobe premiere elements,
and adobe did re-encode it, but the final result was just a black screen.
I think the reason it is so difficult is because there is probably some type
of drm protection in those clips. Does anyone know how I can convert this
.divx file so I can play it on a stand alone dvd player? I paid a lot of money
to get these video clips, I sure would be nice to watch them in my
living room for my own personal use! Please help! -
wow joined in 2003 and only 4 posts. talk about a communication lag lol..
I dont think that its DRM unless you had to download a license for it to play. search for divxtodvd programs. divx makes one
i just found this but the link is only good for a day or so. so i hope you see it before its over.
http://www.giveawayoftheday.com/
its for a free AVI or any format to DVD burn/converter. i have no idea about this pgm but thought of your post.. give it a shot
Can't convert files downloaded from a file hosting site
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 20:27 -
cannot convert downloaded file in xvid4psp
By suevee in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2009, 19:55 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 16:29 -
How do you convert DivX file w/4 subs to AVI?
By JoeBolden in forum Video ConversionReplies: 2Last Post: 21st Nov 2007, 15:58 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 11:54
