Im new to this forum and i know this topic has been covered numerous times although i tried searching the forum i could not find an answer specific to my problem.
I am using Adobe Premiere pro, Audition and Encore. I am trying to make a 5.1 Music video
I have made the multi-track session in audition exported it as a single wave file and 6 mono channel files during playback in Audition and Premiere Pro the song track sounds fine. However when i encode using 5.1 codec (either Surcode or Besweet) i get an unwanted echo in just the song track once its burned to a dvd. I did read in one of my searches that this is due because its processed and processed and the echo is the after effect.
Is there setting in either the codec (Surcode or Besweet) or my software Premiere pro/Audition that can address this problem? I have been able to minimize the echo effect by forcing the song track to be coming from just below the center channel in the Multichannel editor however if your sitting near the rear speakers you can still tell there is a slight echo.
thanks in advance. btw this is my first attempt at making a 5.1 so i am a little new to the process.
can't be done. no way to make 5.1 from stereo sound like 6 channels of mono input. artificially creating 4 channels with always sound like crap.
fair enough, i forced the track with the stereo song just to the center speaker. No echo, however its not really the desired effect. I wanted the song to be in at least stereo. How does hollywood create a 5.1 audio track with a stereo song in it and not make it echo?
Hoping to find out, getting tired of wasting dvd's on each attempt lol. -
#1-Use RW discs
#2-HOLLYWOOD either uses "5.1" surround songs, or leaves the "stereo" songs in the usual L+R channels, and leaves the other stems (Dialog + FX) to fill their part in the 5.1 mix.
Scott -
Hey, if you wanna make an omlette you have break a few eggs
dvd rw? ppfft, whats that, i just got power hooked up to my igloo last week dude.
Seriously though, i think i figured out some of the problems i was having. about to burn another disc and find out. i'll let you guys know, and thanks for the help too btw.
MP3 - Batch export song number/song title/etc to ID2/ID3 ?
By ralf07 in forum AudioReplies: 5Last Post: 3rd Mar 2012, 02:51 -
A time-lapse video that writes the words to a song as the song plays
By radardetector in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2011, 23:09 -
making video of song lyrics, and adding a song...how?
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 15th Mar 2010, 04:09 -
Unwanted Dolby Sound Mixed In With 2 Channel Stereo Tracks.
By travelagent73 in forum AudioReplies: 0Last Post: 18th Aug 2009, 11:49 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35
