I know that theres a hack code...but..i havent seen one that works yet
I want my Toshiba SD 1200 to play Region 3 dvds.
i dont know if this is right but i tried the code where you have to insert the dvd, wait for error message, press memory, press1, and press play and or press clear after that.
that wont work...XD...;;; im a newbie at this whole dvd converting thing so please help?
How can i make my toshiba SD 1200 play region 3 dvds? ((and also does Best Buy sell regoin converters for dvd players?))
There are no standalone region converters,either the player allows it or it doesn't.Get yourself a Philips player at Best Buy or Walmart,they can be hacked with the remote.
BTW:The SD1200 is the first DVD player I owned,I could never get the thing to play burned media except for CD-R/W. -
Not all players can be unlocked ("hacked"). If there is a known code, it will be in the DVD Hacks section.
Google is your Friend -
i checked the hacks section already and tried the code they have. T___T thats why i was wondering if anybody knew another way to perhaps make it work OTLL;;Originally Posted by Krispy Kritter
I was trying to make two points: First, that not a players can be hacked and it's not uncommon for new versions of an existing player to be locked to prevent hack codes from working. Second, that whenever codes are found they are posted in the hacks section. If someone is nice enough to respond to your post with the code, they shoud have already posted the hack for others. At least that's how the majority of users here act.
No harm in asking, and no offense, but based on all of the posts here, everyone seems to believe ALL players can be hacked.Google is your Friend
help: my copy wont reg it say problem when registering
By besty01 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Nov 2011, 12:38 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
reg converting nd burning dvds....
By liddu in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 05:50 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 11:30 -
Copied dvds wont play on my PC
By Rgalan in forum Newbie / General discussionsReplies: 10Last Post: 21st May 2007, 17:34
