I've read that the correct resolution for photos to be displayed on DVD is 480 in height. But I've also heard that these photos should be designed as 720x540, and then resize them to 720x480. What if I just started them in 720x480?
Does this make a difference? Someone please explain. Thanks!
AnonymousGuest
You heard correct for 4:3 AR (NTSC DVD). If you want to create a 16:9 Widescreen slideshow, start with 864 x 480 images and resize to 720 x 480.....................
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
http://www.kiva.org/about -
What EdDV said -- you can give yourself lots of headaches when converting still images to DVD, based not just on image resizing but also pixel aspect ratio: A camera (digital) photograph has a 1:1 pixel aspect ratio, and a TV image (DV/DVD playback) is 1.093:1, so if you don't correct for that slight difference your converted images look a bit off. If you're working with Premiere than you can automatically set the aspect ratio to correct for that, and I'm guessing most photo-to-DVD software does this automatically, but who knows.
That being said, I wouldn't worry so much about resizing images unless and until you read the manual on whatever program you're using to convert to DVD, as they might have a preferred image size for conversion, or they might do all the scaling for you and you can just drop whatever you've got into the timeline. I use ProShow Gold for my slide/photo to DVD work and the re-scaling of the software is close enough to doing it in Photoshop (in terms of quality) that I can just pretty much drag and drop any image of any size into the program and it'll look good -- relatively speaking -- on a DVD. So I don't worry about the size, I just worry about having a nice picture to start with.
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Correct size Resolution for AVI
By Sliztzan in forum EditingReplies: 45Last Post: 25th May 2010, 11:01 -
Capturing high-resolution photos from Blu-ray videos?
By Saxkat in forum Blu-ray RippingReplies: 3Last Post: 26th Dec 2009, 09:07 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 13:31 -
deciding on the correct resolution setting when converting to mpeg2
By Dreadnaught in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 09:36
