I generally use videos taken from Fraps and convert/encode them to an avi with x264 video (2 Passes & target bitrate of 200) and mp3 audio (usually 20 kBits/s, 8000 Hz, Stereo) using VirtualDub.
The guide here (the section under Two Pass): http://teek.info/guides/video/x264encode.html is pretty much what I do manually each time.
Is there a way to automate this process? I'm aware that Avisynth could be used but I don't know how to write such a script nor do I know how to make a generic script, as from all the examples I've seen, you have to specify which video file name exactly each time. Is there a way to simply pick the source file each time?
I've googled around and found this vbs script: http://www.ericphelps.com/scripting/samples/VirtualDub/index.html but it doesn't seems to really work.
Can anyone can help me write a simple script (if that's indeed what I need) or point me in the direction of a simple program that can do the conversion/encode I need?
I've tried AutoMKV and StaxRip but both seems to be far more complicated than this process needs to be, I can do it faster manually with VirtualDub. Also neither seem to be able for me to specify a bitrate, instead they both ask for a target file size which is not what I want as I don't have any specific file size in mind.
Much thanks.
Results 1 to 1 of 1
Cannot encode my avisynth file
By V-Spatial in forum Newbie / General discussionsReplies: 6Last Post: 25th Feb 2010, 14:13 -
Avisynth + Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 21st Dec 2007, 05:57 -
Avisynth on Virtualdub too large
By mrcoolekin in forum EditingReplies: 6Last Post: 11th Aug 2007, 10:11 -
I'd like to learn how to encode using VDM, AviSynth, and other programs
By Xandal in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2007, 17:20 -
Using avisynth instead of virtualdub?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Jul 2007, 10:23
