Newbie here and have a question. I am going out to buy a new lcd hdtv with 1080i/720p capability. The one I am going to get, already has an ATSC/NTSC/QAM turner built-in. Knowing that, is there any reason I would need to get a dvd player or dvd recorder with a turner built-in also? I am leaning to a dvd recorder in any case so that have the ability to record from the tv if I want to. I would really appreciate your coments and suggestions. Thanks.
	If you wish to record, you will need audio and video inputs.
 Does your HDTV have available outputs to feed a DVD-Recorder? If not you will need get inputs in another manner. If you want to record a program other than the one you are watching - you need other inputs. If from an antenna - you need a tuner. If from the cable box you might need a tuner if no other free outputs are available.
 Without more info one can't say.
	Ones without tuners are the same as the ones you have in your PC but cost a lot more. You can use your PC as a dvd recorder byopvr.com
 Dvd recorders are really tricky to find these days. They are kind of phased out. New ones have hdtv tuners.
  Looking for advice on buying a new DVD recorderBy luvsufo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Feb 2011, 16:10
  Buying old/new DVD/VHS recorder LG RC68233 or LG RC185By bostudio in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Jan 2011, 05:04
  Buying a Blu-Ray PC based recorderBy Zetti in forum MediaReplies: 12Last Post: 5th Apr 2010, 20:31
  Buying DVD HDD recorder in IrelandBy daithi_dearg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Mar 2009, 16:57
  Need advice for buying a desktop DVD recorder.By Xandaum in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Jul 2007, 11:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
