Can anyone hep me with the region free crack for the Targa dvd player.I have looked through a lot of sites and found a lot of conflicting info and a lot of dead links so im at a bit of a loss.
Thanks in advance
Garry
Results 1 to 9 of 9
Record a CD with the .ISO file posted below,
put the disk into your standalone, and PRAY... ^.^;;
targa-dp-5100x.iso -
Thanks midzuki,but when i put the CD in to the player the messagecheck disc is on the tv screen and error on the dvd display,any thoughts?
Garry -
Assuming the CD was burnt correctly (i.e., it contains
a folder named RMTM0000 that contains a folder named
SCARLET that contains a 4-byte long KPJC19_1.DVD),
I can only conclude the firmware of your Targa DVD-player
requires a newer hack (or worse, it cannot be hacked at all).
just checking,i burned the cd as a data disc is this correct?
i will check the firmware version.
Thanks again
Garry -
The firmware was updated before as per the targa site,do i burn the file that you gave me straight a cd.I saved it to my desktop then burned it using nero,was this right?
Garry -
If you chose the option "Burn Image" in Nero,
then you did the right thing. But if you simply put the .iso
file on the root directory of a data CD, then you did the wrong thing.
Midzuki,i just burned the file
,now copied the image and workd perfect.
Thank you again
Garry
targa dvd/vhs recorder won't recognise dvd+rw discs.
By steve6 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 31st Jan 2011, 16:04
