Hi there,
I'm making a new media PC for my living room. I've read that you can use the XBOX 360 HD DVD player as a cheap HD DVD player for your PC by connecting it to a USB2 port. I'm interested, but I want to make sure of the following:
1- Will it work on Windows XP SP2?
2- Is it possible to use Media Player Classic to view HD DVD movies?
3- If Yes to question 2, will I need any (free) Codec to view the HD DVD movies in Media Player Classic?
4- Will the XBOX 360 HD DVD enable standard DVD playback and allow files to be read from a data CD or DVD (I would like the drive to be the only optical drive on that computer).
5- What the minimum requirement for a PC to be able to read HD DVDs (CPU, RAM, Video Card)?
Thank you for your time
The htpc/media center forum section is better for this. Moving you.
1. Yep.
2. Not if you want menus and such. You might be able to just play evo files if you have a h264 or vc-1 codec but I would use PowerDVD.
4. Don't know.
5. http://www.cyberlink.com/english/support/bdhd_support/system_requirement.jsp -
Originally Posted by Baldrick
Oh man, I just downloaded CyberLink Advisor to see if my main PC (one that's more powerful than the one I'll make) is capable to play HD DVDs and $%^# No!
My main PC is a 2.8 P4 and my Video Card is an FX5900 and according to CyberLink Advisor, it's not enough, so $%^# that! Man, this is typical, an HD DVD player is nothing but a dumb underpowered computer and yet, it can play HD DVDs. The same thing with DVD Recorders, they are retarded compared to PCs and yet, they can record on the fly and finalize the recording in seconds while a PC will need about 200Gig for storage (on the fly not recommended for PCs) and will take 2 hours to finalize the recording due to compression and $@!#.
Life's not fair
Can't the 360 be used as a media center extender still? I mean you won't be able to play HD-DVD on your computer but at least you'll be able to use your networked 360 to playback content from your Media Center PC.
FB-DIMM are the real cause of global warming -
Yes that is correct. Works great for that as well.Originally Posted by rallynavvie
Is there a dvd player that you can select ycbcr601 other then the Xbox 360
By Evil Monkey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jun 2009, 09:44 -
Xbox 360 HD-DVD Player on PC
By WiReTaP in forum User guidesReplies: 48Last Post: 26th Dec 2008, 13:35 -
Amazon.com: $80 Xbox 360 HD DVD player + 6 HD DVDs
By louv68 in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2008, 14:25 -
XBOX 360 HD-DVD Player problem
By maldb in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Dec 2007, 20:25 -
By Tchail in forum Software PlayingReplies: 6Last Post: 10th Oct 2007, 15:07
