Hello
I am using Encore CS3. I have installed this very recently. As I tried to author my first DVD, I could not find any templates in the Library section either under Menu or buttons or anything else. There is only one thing being shown under Library and that is "General". But there is no menu templates in that too.
I tried to search the installation DVD but could not find any templates. I tried to reinstall EncoreDVD, but that did not solve the problem
I am using Windows XP Pro.
Could someone please tell me where and how can I find the templates?
Please help.
Thank you.
PS: I know there are other DVD authoring softwares available, but I have to complete the project in EncoreDVD. So please give advices specific to this software.
But I could not find anything in the installation media? I mean the installation DVD no 1
It's not on one of the four software installation discs. It's on one of the supplement discs.
Hello lordsmurf
Thanks for the reply.
There are 8 DVDs in Adobe Production Premium CS3. Could you tell me which one contains this and how do I install these extras? While I installed Encore CS3, it never prompted me to install the extra quantities. :O -
It should be in your first installation disc and should have been installed automatically. Either you should contact adobe or check out if Corporate editions include those templates. I am not really sure about the difference between Corporate and Retail versions.
আমি বাংলায় গান গাই -
Multi-licensed editions have it.
Cannot find menu in BDEdit
By kpic in forum Authoring (Blu-ray)Replies: 0Last Post: 18th Apr 2011, 15:19 -
Full motion menu creation software with templates?
By TVJunkieLI in forum Authoring (DVD)Replies: 2Last Post: 7th Apr 2011, 09:54 -
Where to download menu templates - Corel DVD MovieFactory 7
By Roundabout in forum Authoring (DVD)Replies: 4Last Post: 13th Feb 2011, 17:59 -
Customized DVD (and possibly Blu-Ray) Menu Templates
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 17:02 -
How to edit menu templates in convertXtoDVD
By oodles in forum Authoring (DVD)Replies: 3Last Post: 16th Jun 2008, 12:16
