Cool thanks for the advice. Maybe you can help me with this problem I am having since I am pretty new to AVIsynth. I captured some TV clips like I said with my Hauppuage PVR. I originally tried to use directshowsource and go the error that I needed to put in framerate. I looked at them in Gspot and it says the frame rate was 29.97fps. So I then put that in as the parameter and it said it could not open it. I searched around and came across the mpeg2.dll and mpeg2source information. Then following your instructions, I downloaded DGIndex and put in the DGDecode.dll into my windows\system directory. I used DGIndex and opened my TV capture and saved it as a .d2v file. My .avs file looks like this:
LoadPlugin("C:\windows\system\dgdecode.dll")
MPEG2Source("C:\MyVideos\test.d2v")
and the error I get is unable to load d2v file. Any advice? Thanks.
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 18:58 -
MPEG2.dll
By Black-Logik in forum Video ConversionReplies: 6Last Post: 21st Mar 2009, 03:40 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 14:34 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 18:28 -
MS wmp.dll was crashing in VB
By gll99 in forum ProgrammingReplies: 0Last Post: 14th May 2007, 13:19
