Hello experts,
First time poster- but then again i just discovered this site!
I am working on a spot which is going to be broadcast on a cable TV show (an intro), I was wondering if you all can tell me
what format is best to render in (I'm using Sony Vegas) to broadcast on TV? Is it .avi, uncompressed? I want high quality sound and picture (as it appears on my computer).
Also, what about in HD? I'm currently rendering HDV in MPEG2 (.m2t) format. Will the output be as good on cable television?
Thanks!
	Welcome to the madness.
 I suggest you author a DVD-R @ 720x480, 6Mbps with PCM (WAV) audio. Then the broadcaster can simply play the DVD into their system.
 If you plan to produce a High Def DVD, you'll need to look into an authoring program that is High Def capable.
	What is your source format?Originally Posted by adam08
 Is this for cable access? If so they usually have a tight definition for acceptable media. Around here, this is usually S-VHS or MiniDV format. DVD is accepted only in preapproved format. Commercial spots would have other definition, usually Betacam SP or Digital Betacam.
 If you are talking about something like The Discovery Channel, then you would be talking HDV, HDCAM, XDCAM, DVCPro or Digital Betacam.
 Those are tape delivery formats. Video render formats would be high bitrate 480i (either DV or uncompressed 4:2:2) or 1080i (HDV or uncompressed).
 PS: If you are just delivering a clip to be edited into a show, talk to the show's Producer. He/She are responsible for the final delivered product.
  New Media center file .WTV format problem with Silicon Dust Cable Card PVRBy torrentlord in forum DVB / IPTVReplies: 3Last Post: 18th Sep 2011, 01:08
  Question on HDMI cable formatBy Kev90 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2010, 23:19
  Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable boxBy aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21
  HD Sat channels - what format they broadcast in?By snadge in forum DVB / IPTVReplies: 9Last Post: 8th Feb 2009, 07:57
  digital cable = the new svcd format?By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 02:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
