What I'm looking to do is have all my cable TV stations on my PC, but be able BROWSE the stations with the station listing menus that a lot cable providers are offering today. Also, to be able to select shows and have them record (without having to enter in times as I would when I use my VCR to record TV shows).
Here's a website you'd be interested in for certain:
http://www.byopvr.com/
As for trying to browse, record and view your cable stations, look into any of the myriad of TV Tuner cards out there. Depending on your needs they can be under $50USD or more than $500USD.
Happy hunting!
TTWC"I've got a present for ya!" - TTWC -
I am in the same situation BUT on digital cable, HD.
Is there a card that can accept Cable Card or record the HD signal after the decryption (fireware or component)? -
sorinicu, check out the link I provided in my previous post. There are numerous people using HD digital cable as their input, and there are options for those who want HD signal capture capability.
Best Wishes!
Having built a PVR, it's a handy device when you need to record long runners (i.e. my son has a habit of locating 24 hr cartoon marathons) and want better quality than DVD recorders have on 6 hr mode (UGH).
Anyway: this is what I used:
old Compaq case - LP PCI slots (that's Low Profile) - won't go that route again, too hard to locate cards, too limited on the choices you have. One redeeming quality: It is only 3 or 4 inches high, so doesnt stand out in the video rack.
removal hard disc bay (turn it off, slide it out, take to other PC for editing)
Hauppauge PVR-150 LP PCI card. 250 or 350 would've been better, but I'm cheap.
1GB RAM. Actually this is in excess, as the PVR150LP has a built in MPEG2 encoder - it does not hardly use the processor or memory AT ALL.
40GB HDD that i had laying about.
MoBo that I had.
RAM that I had.
Total Cost: probably about $200 in components, plus my time to set it up.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Sounds like a simple enough setup, classfour. I was wondering, did you have any problems sharing that 40GB hard drive with the OS? I built a PC-based PVR and used a 60GB for my OS drive and a 250GB for the capture drive. I wouldn't have wanted to have my OS drive thrashing around while attempting to record on HQ setting, so I opted for a separate capture drive. I was just wondering your thoughts on sharing the OS partition with the capturing partition?
Cheers!
Tivo tcd652160
By joecass in forum Off topicReplies: 1Last Post: 28th Oct 2010, 23:32 -
TiVo HD to DivX?
By clemon79 in forum Video ConversionReplies: 7Last Post: 5th Apr 2010, 13:56 -
Tivo and Nero
By zdamons in forum Authoring (DVD)Replies: 2Last Post: 11th Oct 2009, 05:06 -
Tivo on PC
By akrako1 in forum Latest Video NewsReplies: 6Last Post: 1st Oct 2008, 18:44 -
Tivo to PC ?
By vodmare in forum DVD & Blu-ray RecordersReplies: 18Last Post: 29th May 2007, 15:54
