I'm new to this forum and have little experience working with video.
I have a showreel (for Games music) which is only 5.30 in length and includes audio. I plan to present the video as part of an enhanced CD (to include audio tracks for CD players) so would need it to be a file size of about 400 MB.
I produced the video on imovie but initially found compatibility problems with the video on PC's. Friends informed me to bounce the original DV file (@1.4 Gb) using my PC instead to avoid this problem.
Having tried numerous times I have not found a solution that looks ok or works on Windows Media Player, Quicktime etc....Bearing in mind I'm paying for the copying and packaging I need to ensure the video will play on various software. I've been told AVI is the safest format for this but have found it difficult to get a file down to size. Because the footage mainly comprises in-game graphics the end product doesn't need to be super slick.
I'm using a freebie piece of video conversion software at the moment.
What should I consider for fps (a friend ssays no lower than 23.8) and compression type.....is this why some aren't always compatible?!?!?
Please any help would be gtreatly appreciated as I have a deadline looming!
Closed Thread
I've just got a version (185mb) that runs on windows media player and VLC but not on quicktime....which I'm assuming only runs mov's. Is there a file type that is compatible with all the most common bits of software or is there always going to be codec (windows media player) or compatibility (quicktime) issues?
markwhite1980, Please do not post the same topic on several forums.
Please do not cross post, once is enough. Continue in:
https://forum.videohelp.com/topic340214.html#1773590
Moderator redwudz
Format settings GOP?
By rocka in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2023, 09:08 -
Best settings and format for ARCHIVE footage ?
By Bansaw in forum Video ConversionReplies: 11Last Post: 28th Apr 2012, 10:55 -
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
Questions about format and settings
By joeplaysguitar in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2010, 18:36 -
Best Settings - How to compress 5 min Showreel
By markwhite1980 in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2007, 23:00
