Good day all.I have downloaded my camcorder discs to my HD Recorder.I then burned the footage files to DVD-RW DISC on the same HD recorder successfully. I then tried to copy the disc which is a minus RW to another dvd minus R disc using my computer and Nero Smart smart.However I'm unable to do this as I keep getting the message"There is not enough space available to burn the image"When I enter OK I get another message ie "Not enough space to copy the disc. Free space is 1491mb.Size of image file is 4482mb".I know this is nonsense as I have tried a number of new blank 4.7 gb discs and still get the same message.I'm using a Phillips internal dvd burner and a Emprex 16x external usb recorder. I have tried changing the recorders setting between source and destination but it made no difference.The dvdrw with files on play ok on my dvd player and computer.Can anyone please advise me as to how to copy these files to a DVD-r DISC.ps the computer tells me that the files currently on the CD are Video.RM and Video TS.
Many thanks for you help in this matter.I hope this question is not to long as I am new to the forum.
Regards 306James
I think it's complaining about disk space NOT space on the DVD media.
A copy is normally a two stage process - read the original and store on HD then write the copy.
Either try making more disk space or have a look at the various options and see if it will copy "On the Fly" which will write the copy as it reads the original without the need for intermediate files on teh HD. -
Hi.all.Many thanks for your replies.Yes you were correct in that I didn't have enough HD space.I have now cleaned up my HD and have burned the discs ok.Will now invest in an external back up HD.Once again,many thanks .
306james
LG RHT497H - copying from DVD to hard disc
By jollysuper in forum DVD & Blu-ray RecordersReplies: 4Last Post: 23rd Apr 2012, 04:59 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 04:44 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 04:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 12:50 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 15:26
