Hi,
Sorry if i spelt it wrong or have the wrong word. I mean the menus where you start off in a room and you can browse through the enter room when you click on a button. Is this done with video. That is, would I have to make a video clip of me browsing through the room then edit the video in such a way that i break each part of the room as a seperate video clip. Or can i do it with just pictures. I honestly don't know those are the two things that came to mind when i thought of it
Can anyone help me with this
How's My English?
I haven't done that, but it sounds like something you could do with a authoring program with hidden menu buttons on objects or areas so you could go to a different view.
Or do you mean a 360 degree view? That would be a bit more complex. Some examples: http://www.panoramas.dk/ -
A menu with such effects is usually a combination of stills and motion menu cells called menu transitions. Some authoring applications are capable of generating such transitions for 'standard' effects. E.g. in DVDLab Pro there's an option for panorama menu creation: you load a panoramic still for authoring and the program creates motion transitions where a user goes from one part of picture with its own button set to another part (left-right direction). More complicated transitions may want specially encoded clips and non-standard tricks.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
DVDStyler query...
By mjl1297 in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 06:36 -
Vegas 8 query
By Fukushuu in forum EditingReplies: 6Last Post: 1st Feb 2009, 22:41 -
Resolution Query
By anirban in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2008, 03:48 -
LG2T160 Query
By coolboarderguy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jul 2008, 09:07
