Hi newbie here, hope you'll all be kind to me
I'm a recent Mac convert, after being a microsoft dude for ages- and am having a problem as i have never used a mac before or done any type of video encoding would really appreciate all of your expert help.
what i would like to do is to encode ingame footage of dreamcast game, then cut it together to make a movie and watch it fullscreen or burn it onto a dvd
I have the elgato eyetv hybird capture device connected to my dreamcast via composite - though that will change when i get my s-video cable through the post
I also have the encoding program IShowU and have tried many alternatives to encode it at reasonable codec for great quality and more importantly disk size but I still cant get a decent enough great quality when i view it in fullscreen on my 24" iMac - am i being paranoid or is this the furthest i can go
anyhelp would be greatly appreciated for a newbie, thanx in advance![]()
You would use iShowU to encode the "hijacked" footage
in DV PAL Stream format, which is the highest you'll be able to capture
(uncompressed). Then, this footage would play back
on the iMac using Quicktime Player in FullScreen.
This would be the best you can get on the iMac.
If you do not have enough HD space to encode to DV PAL Stream
( 1 hour of footage equals 13GB) , then this will be a problem
you'll need to fix by deleting some unused files.
Also, you have enough Ram,you should be ok in your encoding,
unless Leopard isn't playing nice with the ElGato."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Urban Mac User -
is it easy to convert the dv into a playable dvd as in encoding (sorry if newbie question)
Yes, you can import the DV Stream straight into iMovie
or FCE / FCP, and then edit out any undesireable parts
(false starts, etc) and then with iMovie, route it over to
iDVD to make a playable DVD, or in FCE / FCP, create
DVD assets in Compressor to hand off to DVD Studio Pro
to make your DVD."Everyone has to learn, so that they can one day teach."
Urban Mac User
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 15:54 -
Dreamcast video
By Avatar in forum Newbie / General discussionsReplies: 24Last Post: 10th Sep 2009, 20:38 -
Unlikely console revival - Dreamcast ??
By Noahtuck in forum Off topicReplies: 9Last Post: 8th May 2009, 20:44 -
Is the Playstation 3 destined to go the way of the Sega Dreamcast?
By yoda313 in forum PollsReplies: 32Last Post: 21st Jan 2009, 18:18 -
Problem with imac G4
By matw79 in forum MacReplies: 1Last Post: 14th Jul 2007, 07:55
