hi
am a new to this video encoding section .. i hav to convert dvd to avi or any other format or DVD to DVD..
i hav used DVD REBUILDER for converting DVD but mie output was same as the orgninal the encoder is CCE with 5 passes..
To convert dvd 2 avi used TMPGEnc 4.0 there was no quality improvement in avi same like orginal
please say
* how to convert?
*which encoder is best to convert
* and settings to convert
advance thanks.
and sorry 4 my bad english..
waiting 4 ur help guys...
	Convert what to what? For most X to Y, there are guides to be found under Convert left, like AVI to DVD: https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=AVI+...or+List+Guides
 When converting from one format to another, never expect any quality gain, only loss.
 5 pass encodes is basically just a waste of time. IMO, 3, possibly 4 (even if I doubt the latter) makes any real difference.
 /Mats
	thanks a lot will this make the quality better than the orginal..  hey u r given 4 only avi to dvd wat abt dvd to avi hey u r given 4 only avi to dvd wat abt dvd to avi
	The quality will NEVER be better than the original. No way, no how. If it looks the same, you have done the best you can.
 There are detailed Guides for every conversion you could want to do.
	When you convert one format to another, the quality will at best theoretically be identical. In practice, you always end up with a slightly (or significantly) reduced quality.
 I provided just a sample link for AVI to DVD. If you click on Convert left (https://www.videohelp.com/convert), there's a dropdown menu where you can select from and to formats (Right beside the text "Format Conversion:").
 /Mats
	thanks for u reply guys
 the last one which tool will prefer 4 encoding dvd to avi n avi to dvd..
 bye
	AVI to DVD: FAVC, Convertx2dvd - Or if you want to do it yourself for each step: AviSynth + HCEnc + ffmpeggui + DVDAuthorGUI
 DVD to AVI: Avi.NET, AutoGK - Or if you want to do it yourself: vob2mpg + VirualDubMpeg2 + XviD codec (+ DVDFab Decrypter to rip the DVD to disk to start with).
 /Mats
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
