Is there an app that can take an avi and save it as a series of stills. I am working on an interaction but I can't use video footage. So I need to simulate it by using still frames. The avi is MJPG - motion jpeg. I really wanted to use virtualdubmod and some filters I found but it doesn't seem to have the capability.
“He who makes a beast of himself gets rid of the pain of being a man.”
Not sure about virtualdubmod but in virtualdub..
file>save image sequence
Alternately you can use the mark-in and mark-out to select a specific section. You can also adjust the frame rate so it will only output every other frame or whatever. -
Coalman, that is exactly what I wanted. Thank you.
and PEACE.“He who makes a beast of himself gets rid of the pain of being a man.”
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
cutting and saving a section of video
By aldago in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2010, 18:42 -
converting .jpeg into video format for slideshow
By rosmari in forum Video ConversionReplies: 40Last Post: 1st Aug 2009, 09:23 -
saving edited video
By zulubase in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2009, 20:48 -
Saving a single Frame as a Jpeg
By acestu in forum EditingReplies: 0Last Post: 20th Aug 2008, 15:11
