When i make an AVi into a VOB with DVDFlick, it creats 2 VOB files?
When im using GUIDVDAuthor to make the dvd menus and label the titles etc... which VOB file do i drag across???
It created the DVD Files (Video_TS and everything but now i want to make menus...)
Do i need to attach ALL the VOB's 2gether? Its 3 AVI's so ive got 6 VOB files...And if i do this will the 3 AVI's still show as different titles in the main menu? Like if i cant drag each one and set a name for each title i cant see how im creating a main menu if i use just one VOB?
you need both. The DVD spec says that no VOB file may be larger than 1000MB. If it is going to be larger it gets split. You can join them with VOBMerge or extract the mpg content with VOB2MPG and use that instead.
Either way, GUIForDVDAuthor will split the VOBs up again based on how oyu author the disc.Read my blog here.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
DVD Flick- Disc Menu Navigation Question
By ellentk in forum Authoring (DVD)Replies: 0Last Post: 25th Aug 2011, 10:00 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
Create DVD with selectable data file within main menu, help?
By Distearth in forum Authoring (DVD)Replies: 1Last Post: 2nd Jan 2010, 18:45 -
DVD skips the menu and automatically plays the main movie!
By kreky in forum Authoring (DVD)Replies: 7Last Post: 17th May 2008, 08:14
