Hi all
I see that Raw DV uses a bit rate of 25Mb/s and High Definition also uses up to 30 to 48Mb/s - so is it adviseable to convert my travel videos which are on DV tape to High Definition - I mean is this possible to do (I mean to 720x576x50i for PAL) ?
Shelton.
Results 1 to 12 of 12
Converting something to a higher bitrate or resolution isn't going to improve it and in most cases will make it worse. The best you will ever have is the original copy.
no - what i mean is convert my DV footage to HD using 25Mb/s - is this possible ?
For what purpose?
If you play these to an HDTV, the HDTV will handle the upconversion.
In the fuure you might want to upconvert these to edit with native HD source. You shouldn't alter the DV master tape. -
Makes no difference what you're doing... whether going from x to y format or y to x format. Minor filtering and other tweaks which can sometimes be beneficial aside, any conversion of video causes degradation and provides no end benefit except for specific purposes such as if you need to convert it to MPEG for authoring a DVD.Originally Posted by BF109
As mentioned just let the hardware do the conversion on the fly.
The best you will ever have is the original copy. -
I agree with BF109 and like his idea. It would be possible to improve the picture quality by converting DV avi directly to HD video. DV converted to mpeg2 and recorded to SD DVD has a noticeable quality loss due to bitrate limitations. The upconvert HD player will only upscale the video to HD format but will not recover the losses.
Maybe it is already written some special scripts for Avisynth to convert DV avi to HD mpeg2 or etc..? -
There is an Avisynth script & function called iiP (Integrated Image Processor) that can upconvert from 720x4xx to 1280x720 (preferred) or 1920x1080. Go to the doom9.org forum and search that thread. Warning that script/function is SLOW SLOW SLOW and even SLOWER than that, so be prepared to wait a while, but the end esult is worth it. If you have a DuoCore Quad processor, then forget what I said
Speed-up will be noticeable
Thanks for an idea.
I will try to read more on doom9.org about iip function.
So far I have found that it works on progressive mpeg2 source. -
I still see no reason to upscale from your DV master unless you are importing the material into an HD production.
http://www.kiva.org/about -
O yes, of course it will be used for creating HD DVD for example.
The HD video content might be even burned on a standard DVD disk as a 3xDVD. -
guys, he is obviously experimenting here. There is still room for that.
How to duplicate high-definition Video ?
By AAC in forum EditingReplies: 9Last Post: 5th May 2011, 10:45 -
High Definition Video on SD DVD
By TheLaserdisc in forum Authoring (DVD)Replies: 6Last Post: 19th Apr 2011, 22:42 -
Software like vDTS for High Definition video ?
By Zetti in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 18th Aug 2008, 14:01 -
High Definition video converting to DVD
By Turvy in forum Authoring (DVD)Replies: 5Last Post: 14th Jan 2008, 09:50 -
video 8 to high definition
By devdev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jan 2008, 14:31
