Hi,
I'm new to all this - just bought an HV20 and trede to capture video onto my PC but am having no end of problems....
Firstly - I tried Ulead VS11 but it the "capture button" is greyed out so I cant even start captruing it in there. I then Tried using HDVSplit after reading some forum posts, and this seems to work OK, but the captured video has some flickering horizontal lines across it. Hard to describe - they seem most prominent when the camera is moving.
Any ideas? Is my graphics card not up to it? I have a Geforce 7300GT 128MB and I;ve just built my PC, core2Duo 2.67 + 3GB RAM so I think my PC should be high enough spec....Maybe I have got some settings wrong somewhere? Doesn;t seem to be much to mess around with on HDVSplit so am I doing something wrong the camcorder end? I tried playing it straight into my TV via HDMI and it looks spot on - no flickering lines present.
Joe
				Results 1 to 20 of 20
	OK - I tried CAPDVHS too and got the same flickering lines.
 I'd be REALLY grateful if someboyd coudl let me know where I am going wrong....
 Joe
	Are you unaware that you bought an HDV camcorder? You can set it for normal DV. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Yes, I am aware that my camcorder is HDV - I'm trying to capture the footage I have shot onto my PC so I can edit it. Like I say, HDVSplit works apart from the horizontal lines whenever there is any kind of movememnt in the footage.......
 I'd like to be able to play back the edited footage on my HD TV ultimately.......
 Joe
	You have to describe the problem better. Post a screen shot of the "flickering"
	I've been trying to do a printscreen, but can;t even get that to work - it just gives me a blank frame :'o(
 I'll keep working on that one....
	As the guns1inger sayeth, it's normal interlacing artifacts. There's nothing wrong with your camera - you're just learning how to use it. You can play back the video with deinterlacing turned on and the horizontal lines will be gone.
 Interlaced
 Deinterlaced
	Ah ok - thanks for the help guys  ) )
 So do I need to edit it on the PC, then save it in 2 different formats, one for TV and one for PC?
	So far all sounds normal.
 You'll need VideoStudio 11 Plus if you want to capture and edit in HDV mode. Otherwise switch the cam to DV transfer and edit in standard definition DV format.
 http://www.corel.com/servlet/Satellite/us/en/Product/1177439577322
 If you want to shoot and tape HDV but transfer normal standard def DV 480i make the switch here.
 Note: Your PAL model will show "576i"
 You have four format choices with the HV20. If you want to try progressive 24fps make the choice here.
 You will need a tripod and controlled camera movement for best results at 24p.
 I suggest "HD Standard" 1080i 25 fps (50 fields per sec) for normal shooting.
	Joe, firstly Ulead VS11+ won't capture HDV from your HV20. I also have one and had the same problems. If took a month of back and forth with Corel before they admitted that it wouldn't do it. I now capture with WinDv. I tried HDVSplit, but I couldn't get it to recognise the camera being there. Any suggestions? I tried opening HDVSplit before and after turning on the camera and it still wouldn't see the camera there. I use Sony Vegas 7 for my editing, but this, like VS11+ fails after a few minutes of capture and I don't now why. I would love a solution to that if anyone has one.Originally Posted by jmunns
 P.S. Joe, check out http://www.hv20.com
	I've got the NTSC model HV20 and haven't had any HDV capture issues with Vegas 6d or 8 (I skipped 7). Maybe there is a PAL specific issue.Originally Posted by kadzbiz
 I don't have Video Studio 11 Plus. I was just referencing their spec.
 I'll have to try HDVsplit. Others have said it works for the NTSC HV20.
 I'll have to try HDVsplit. Others have said it works for the NTSC HV20.[/quote]
 I have the NTSC version also. I just tried using an external hard drive to capture to and also the idea of plugging in the firewire after the camera is turned on. Still can't get HDVSplit to work. Vegas froze after about 40 seconds even if I didn't start capture. Just the fact that the camera was connected by firewire still made Vegas capture freeze. I dunno. What's up with that?
	Um, I've loaded it on. Run it, but don't know what the heck to do to start capturing. Said to add a job. I see the button, but how do I add a job. If you can give me a step by step, that would be great. The camera looks like it's acknowledged as being connected.Originally Posted by edDV
	See my post about DirectX in the other thread "Canon hv20, 24p hdv, and recommended capture method?"Originally Posted by jmunns
  Canon hv20, 24p hdv, and recommended capture method?By joshcali in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 4th Mar 2012, 19:28
  Firewire capture fom Canon HV20By johnwc in forum Newbie / General discussionsReplies: 8Last Post: 6th Jul 2010, 10:59
  HDVSplit Capture from Canon HV20 is all RED??By cgott42 in forum Capturing and VCRReplies: 7Last Post: 14th Sep 2009, 23:23
  Please Urgent Canon HV20 Audio Capture HelpBy kadzbiz in forum AudioReplies: 3Last Post: 11th Dec 2007, 03:53
  Canon HV20 live capture questionBy bryant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 27th Nov 2007, 12:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
