Can someone please tell me why the size of my dvd files (if I use CCESP) are only 1.3GB? It works right if I use HCenc but for some reason the file size is always way too small if I use CCESP? Thank you.
Simple. It's likely the bitrate settings are different for the two encoder programs. Bitrate determines video size. There are bitrate calculators that will show you the proper bitrate for the desired final size. Some from our 'Tools' page:
https://www.videohelp.com/tools/sections/bitrate-calculators
And you might want to check the audio formats also. AC3 is probably the most universal. WAV or PCM audio files will be much larger and take up space that could be better used for higher video bitrate. If one encoder used a PCM format and the other a AC3, they will be different sizes, though the video may be the same size.
You can drop your encoded files into Gspot 2.70 and see what their bitrates are.
And welcome to our forums.
I like AVStoDVD and use it all the time with HCenc. It does not appear to be the best choice if you want to use CCE. At MrC's forums there have been many posts trying to troubleshoot CCE problems.
From the forums:
However in the next release I'm planning to stop CCE SP support (is anyone still using it in AVStoDVD?), to include HCenc in the installer package and to use HCenc as unique "Very High Quality" encoder. What do you think? -
Really don't know. I did some testing on CCE SP (2.5, 2.66 and 2.67 trial) at the beginning of AVStoDVD development but now I am going to remove support to it because I would like to push AVStoDVD user to fully adopt HCenc which is really a great (free) 2-pass mpeg2 encoder.Originally Posted by ntruax
By the way, some TBS:
1. Which CCE SP release are you using?
2. What type of input file are you converting? XviD? DivX? DV? What else?
3. Can you email me or post here the 2 log files examples (one for CCE SP and one for HCenc, same input file)?
Bye
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 11:52 -
An AVStoDVD non-starter (file-system limitation)
By Seeker47 in forum Video ConversionReplies: 9Last Post: 24th Nov 2010, 10:53 -
File Sizes
By rhodellf in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2009, 12:51
