Subtitle Workshop is crashing every time after I load a subtitle file (tried both .srt file and .ssa file). This seemed to start occurring after I upgraded to nero7.
After researching for quite a bit, I found out that this may be a problem with vobsub? Someone suggested disabling vobsub, and that seemed to stop the subtitle workshop crashes. HOWEVER, I had to use the internal subtitle viewer in SW and I couldn't get subtitles to display anymore with media player classic (since vobsub is disabled).
Is there any way to get BOTH SW not to crash AND enabling vobsub so that I can see the subs with using MPC?? This setup worked perfectly fine before the installation of nero7...
Thanks in advance to those kind enough to help!!
Results 1 to 10 of 10
I had a similar problem.
It seems some automatic subtitle viewer was displaying the subtitles of a movie when I opened the corresponding AVI file (eg, "video.avi" and subs in "video.srt").
Mostly this is fine, but Subtitle Workshop would get screwed up because it was also trying to display the subtitles.
I found I could prevent the autoloading by renaming the subtitle file.
Renaming the subs (eg, to "video_.srt") stopped the autoload.
When using Subtitle Workshop, you now have to select the SRT and video files explicitly.
When you're done editing subs, you can change the name of the SRT back if you want. -
I sew this movie few hours ago, and I said to myself I must show this to my little sisters. So I decided to tittle it on my language. I asked a computer-wizz what should I use for such a job and he said Subtitle Workshop.
Now. My prob is same as yours. But. I cant make out what are u guys talking about? If u cant translate how to fix a prob on dummy's language I would appreciate it.
If this means anything, I'm using Windows Media Player Classic with output set on: VMR9 ( renderless )** (so I can use tittles in Windows Media Player Classic), and Nero 8. k-lite codeck pack is 445. Thanx in advance
I said:Originally Posted by XXIX
ThenRenaming the subs (eg, to "video_.srt") stopped the autoload.
1) open the SRT file. It should NOT automatically load a video, as it has a different name.
2) open the video ("Movie/open"). You should only see one set of subtitles.
3) edit your subs
4) exit Subtitle Workshop
5) rename the SRT to its original name
Now opening the video in your player should find and display the SRT.
Subtitle Workshop Crashes
By randy3101 in forum SubtitleReplies: 5Last Post: 6th Jun 2012, 16:32 -
subtitle workshop crashes when loading video
By stem300 in forum SubtitleReplies: 0Last Post: 29th Dec 2011, 16:37 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57 -
Loading subs with dvdsubedit
By aruwin in forum SubtitleReplies: 2Last Post: 24th Nov 2008, 04:00 -
ffmpeg.exe crashes when loading an asset
By boggle in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Jul 2007, 13:55
and the problem is gone!
