  1. Banned
    Nov 2007
    hello everyone,
    i am downloading a movie which has loads win rar archives,does anyone how to convert the files?
    thank you all in advance
    Feb 2007
    What do you mean by convert?
    If you mean you have a series of files file.rar, file.r01....file.r99 then just open the .rar with winrar and it will automatically find and open all the rest - it will also report any missing parts as well.
    If I'm misunderstood please rephrase your question.
    M
    Aug 2007
    If your looking to combine the rar files, one of these apps may help:
    WinRAR
    7-Zip
    IZarc
    Jun 2007
    Remember, you have to have all the parts to extract the movie, if you're missing even one then the movie won't convert.
    Nov 2007
    I am having a similar problem with all these rar files.
    do i need to extract them into a specific directory like video_ts so they are able to create a dvd?
    and what happens with the 63 unrecognised files that are in the same folder as all the rar files??
    please reply to this someone as i'm completely lost and new to all this
    thank you
    Aug 2007
    You should be able to extract the file / movie / .avi / .iso (whatever you've downloaded) to the location of your choice. Your 63 rar files will remain until you have deleted them. Delete them only after you are certain your file(s) have been extracted (reassembled) properly. Have you installed 7-Zip yet? Is it associated with the rar format file extention?
    More info here:
    http://www.binaries4all.com/7zip/
  7. Banned
    Nov 2007
    thanks everyone for replying,well i need to rephrase myself,what i need to do with win rar is to open all the rar files,i was just wondering if it does automatically,or if it is something i have to do manually.
    anyway your replies i am sure will be very helpful.
    thanks again 8)
