Hello,
I'm having this weird export problem with the latest version of premiere.
I'm creating this musicvideo for a tennisforum, the subject will be the YEC 2007
(Sony Ericsson's Championships).
The theme song will be Daft Punk & Kanye West's Stronger, so i'd like to begin the clip
with 3 premiere layers:
1) A fancy premiere title
2) A big purple semi translucid stroke to accent the title
3) A HQ picture on which the words "MADRID" will be "moved between 2 keyframes"
I've tried almost everything, but don't seem te find a solution to the export. If i use adobe media
encoder, i always get the picture (nr 3) messed up and pulled down. Idem ditto with exporting to
flash video or wmv. The only export that gives me an EXACT replica of what premiere plays in its
preview screen is "export movie -> AVI" but instead of +-120mb i get a filesize of almost 1500mb..
so that's not really helpful if i want to upload it later to megaupload or rapidshare for others to enjoy.
Note: All video that i import play and export like intended, but this "moving picture" is a pain in the ass.
I'm actually not really new to premiere, but it's the first time i ever used this keyframing with still images,
with video it works like a charm though...![]()
Picture 1 is the avi screencap, picture 2 is the "any other filetype exported one"
Nobody encountered the same problem, or tested moving an image between 2 keyframes, adding a title above, and then trying to get it exported to, for ex. windows media ?
export it to avi then import it again in premiere and export to something else
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Premiere CS3 export to HDV - problem with aspect ratio
By perplexityincarnate in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 1st Apr 2010, 10:12 -
Premiere Pro CS3 HDV export
By kippard in forum EditingReplies: 0Last Post: 12th Oct 2008, 20:30 -
Premiere Pro CS3 export
By kippard in forum MacReplies: 0Last Post: 11th Oct 2008, 19:33 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 07:54
