I have some old Laurel & Hardy .avi video clips that have been colorized. I would like to view them in their original B&W form however - what software can I use to convert back to B&W?
Have downloaded Virtualdub but the help section doesn't have any operating instructions (which as a newbie I definitely need!). Any further guidance will be appreciated.
Sorry, please ignore my last posting - I didn't read the link properly!
I have now converted a couple of clips from colour to b&w form using Virtualdub 1.7.6, and using the settings advised in Post 176259 referred to earlier. The only problem is that the resutling output files are MEGA-big e.g. an input file of 181MB produced a b&w output file of 32.8GB, and I'm now nearly out of HD space! What's gone wrong?
Open file in VD,use the instructions as before,in the VIDEO setting check compression and use a xvid or Divx codec ,but they must first be installed of course..If their not installed you'll get the 32.8G output size ,cuz you picked uncompressed and saved....
" Who needs Google, my wife knows everything" -
Any bitrate or "quality" savings you might think you're getting by encoding ONLY B&W are more than offset by the fact that your RE-encoding an already-compressed file.
Wouldn't it be simpler to just (temporarily) turn down the color/chroma on your monitor/TVset when you watch those clips? (From what I know of colorization, they would NOT have messed with the luminance.)
Converting & digitising
By deepu in forum Video ConversionReplies: 11Last Post: 18th Apr 2010, 00:17 -
converting RM & TS Files
By Astonlee in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2008, 08:02 -
converting AVI & Subtitles
By halw in forum ffmpegX general discussionReplies: 1Last Post: 15th Nov 2008, 02:27 -
Converting & Shrinking to 1 DVD
By poppy56 in forum Newbie / General discussionsReplies: 4Last Post: 4th Oct 2008, 15:54
