Hi i just joined this forum, and just wondered if anyone,with some knowledge,could help.
I have quite an old 28'' wide screen tv and would like to connect it to my computer, the route i would be taking is to connect a vga output to a scart input, the guy at the computer shop has a cable like this for me.
My question is would this work, i have an acer aspire desktop computer, with a built in graphics,card, that probably doesn,t have a tv out fascility, what i mean is there is no s video output only vga.
On my computer the lowest resolution i can set it to is (800 by 600 pixels) if anyone has any advice or think they can help i would appreciate it thanks.
The two don't connect well. What are your expectations? A TV makes a poor computer monitor but will be ok (not good) for movies.
VGA analog RGB 800x600 does not directly comvert to TV SCART RGB. That "cable" better have a big electronics box in the middle.
Normal computer interface is S-Video to an older TV. -
Hi the reason i want this option is to watch movies without the convertion, so will the vga to scart option not work, i dont have s video on my computer, nor do i have it on my tv, just scart, thanks.
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
How to connect internal USB 2.0 card reader in older PC?
By bevills1 in forum ComputerReplies: 24Last Post: 15th Apr 2009, 07:05 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 22:31 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 12:41
