I have versions 5 and 6. And for some reason when encoding avi files, when I set the audio compression to Mpeg Layer-3 the only options I get is 24000hz...
I have an older version (Version 3) that came with my capture card. I've been going back and forth uninstalling versions 6 and 3. Version 3 shows all the mpeg options up to 48000hz..What is the problem with the newer versions? any clues? Thanks....Adam
I've tried all the codecs you can think of...It's something to do with Power Director....
seems to be a limitation built into the software. i look at my version 6 and have only the same settings in avi and divx that you do.
Power Director isn't mainstream but there are specific forums listed after google searchs.
Google "Power Director Forum" -
I wonder why they would have limitations on the mpeg layer 3 settings?
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 20:05 -
Cyberlink Power Director does not recognize widescreen
By sektionschef in forum Video ConversionReplies: 4Last Post: 5th Aug 2009, 00:56 -
Cyberlink Power Director 7 - "Create" Function Problems!
By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 21:01 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 22:53 -
Power Director 6 create disc problem (trouble
By tekton364 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jun 2007, 18:35
