No matter how I try I cannot delete frames with vdub. It seems to delete the unwanted files and when playing the output file nothing has been deleted. What am I doing wrong here. I'm feeling pretty retarted here.
LOL.......
OK, all you do is use the black "arrowish" keysd at the bottom to highlight the areas you WANT to DELETE. Then go to edit and choose delete frames or simply hit your delete key. Then when you save your avi or frameserve out it will render your "edited" video from the window.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
This is what I did: Opened file, clicked on arrowish key to start selection with first frame scrolled through found frame to end and clicked end selection, delete key, save as, gave a name, and shizamm not a damn thing changed. What is the problem.
How many frames are you trying to delete?
If it is only a few chances are that they are between key frames. Virtualdub will only allow you to delete from key frame to key frame when direct stream copying. If you re-compress when you save then the edit can be frame accurate.
Does that make sense?
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 18:45 -
VDub, Key frames and syncing...
By takearushfan in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 15:04 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 12:03 -
deleting menu buttons with pgcedit problem
By spiritgumm in forum Authoring (DVD)Replies: 5Last Post: 20th Apr 2008, 19:52 -
Editing / Deleting Sound & Frames
By staminet in forum EditingReplies: 0Last Post: 10th May 2007, 13:03
