I have been wanting to capture my xbox 360 footage for a long time, but i don't kno how to. right now i play on a hdtv and i want to record in either standard or high def. i dont care which one it records on, but i refuse not to play in hd cause i have for a long time. i have heard it is impossible to record while playing in hd unless u buy several converters which can equal up to like $250+. also some1 told me u can record while playing in hd and record it in standerd def, but it will create a lot of screen lag which i don't want. so if anyone can help me find a way to play in hd and record in either def. for at most $150 that would be great. explain everything as much as possible cause im new at this and if you can send links to the items i need. thanks!
Have you read https://forum.videohelp.com/topic317690.html ?
yes, i did just read it and i have a slight idea on what i need and what to do. here is my tv so u kno what inputs/outputs it does and does not have http://www.taaffephoto.com/item_detail.php?item_id=112962
i was looking at this and i think i might try this but what specs do i need for my computer, right now i have a dell laptop intel centrino duo which prob aint the greatest for this.
Originally Posted by 007craft
Capture flash video playing in a web browser?
By sdsumike619 in forum Capturing and VCRReplies: 2Last Post: 14th Nov 2010, 00:28 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
how to capture encrpted WMV file while playing
By steevo in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2010, 13:32 -
xbox 360 capture video and audio while playing on pc monitor
By josh123 in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2010, 02:51 -
Can Windows Movie Maker capture photos while playing video?
By coody in forum Capturing and VCRReplies: 2Last Post: 5th Aug 2009, 21:09
