  1. Hi,
    I've some part of my home DV video which has lot of shaking (dv cam was not on a tripod).
    Is there some filters for avisynth or virtualdub that can reduce the shaking and give a more stable picture ??
    Thanks.
    Apr 2004
    Miskatonic U
    DeShaker for virtualdub can help : http://www.guthspot.se/video/deshaker.htm
    It's not going to give you rock steady images, but it will smooth out a lot of the motion, and stabilse minor movement pretty well. You may find that you need to zoom into the image after you are done to remove the borders you will get form the process though.
    Read my blog here.
