Hi
my standalone dvd player used to be able to play dvd but now no more.i can play cds as normal. any suggestions?
Yes, that sounds exactly like the symptoms my first DVD player showed. First, it gave up playing pressed DVDs. Then DVD-R started to fail, to pretty soon just refusing to accept anything but CD / CD-R disks. It went into the garbage bin.
/Mats -
DVDs and CDs use a different laser in the player. The DVD laser either has a dirty lens or is dead or almost dead. DVD players aren't really built to last and they're very cheap, so you could just buy another one. If you are too cheap to do that, you can do a web search and find out what you have to do try to clean the lens on your player. It probably won't help, but in a few cases it does. If the laser has gone bad and it's not a case of dirty lens, cleaning won't help.
DVD plays on only 1 out of 3 players
By mblaine in forum Video ConversionReplies: 9Last Post: 18th Jul 2010, 02:43 -
DVD plays in LG but not in Panasonic
By dexter30 in forum DVD RippingReplies: 4Last Post: 23rd Feb 2010, 22:26 -
looking for a DVD player that plays it all
By gameroftheuk in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 23:45 -
It plays OK on the PC but not the DVD?
By thief_ in forum DVD RippingReplies: 4Last Post: 12th Jun 2008, 05:52 -
Mpeg Video Wizard DVD: Burned to DVD-R, Plays back with hiccups.
By Giovannini in forum Newbie / General discussionsReplies: 13Last Post: 27th May 2007, 06:54
