Results 1 to 12 of 12
  1. Is there a free program that will let me edit .flv files?
    Nov 2002
    Yes. The new experimental version of Virtualdub 1.7.X with the FLV plugin will open FLV.
    http://www.virtualdub.org/beta/VirtualDub-1.7.X-test5.zip
    http://www.moitah.net/misc/FLVInputDriver-0_3_0.zip
    other plugins...
    http://fcchandler.home.comcast.net/MPEG2.zip
    http://fcchandler.home.comcast.net/Plugins/WMV/
    http://www.tateu.net/software/dl.php?f=qtvd_bin
    You can also use FLVExtract which will give you an AVI and MP3 file which you can also use Virtualdub 1.7.X to put the files together and edit. This is the best option to avoid sync issues.
    Someone should make this a sticky so I don't have to keep posting these links.
  3. thanks i appreciate it
    Sep 2007
    Philippines
    good day sir....flv has been placed in vitural dubs plugins32 folder but still cannot open fl v files...any info will be appreciated
    tnx and more power
    Nov 2002
    What version are you using?
    The plugins were created for 1.7.X which is shown in the link above. It will work in 1.7.6 but I don't know if it will work in any older versions.
  6. Originally Posted by android6011
    As above (VirtualDub + FLV input plugin) and... Avidemux or Movica (split & join).
    Nov 2002
    The version that I posted is 1.7.X ( the X is for experimental ).
    Download from the link that I posted.
    Anything older than version 1.7.6 can not use the plugins and version 1.7.X is updated to fix bugs and to work better with these plugins.
  8. Originally Posted by DarrellS
    Yes, it's test version.
    But...
    Originally Posted by phaeron
    Alright, enough of this "stable" crap. Time to show what I've been working on in the other branch.
    Why's it called 1.7.X? Because I don't know when it'll be released. So far, it looks like it'll be at least 1.7.8.
    Not exactly.
    API plugins support added in 1.7.2 version.
    Of course better use new viersion (fix bugs).
    Old 1.7 (before 1.7.6) = experimental
    1.7.6 = stable
    1.7.x = test (very experimental)
    BTW
    VirtualDub and Avidemux not support variable frame rate (VFR) - possible desynchro A/V.
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Or movica, avidemux. No reconverting is required but it may not work with all flvs.
  10. Originally Posted by Baldrick
    Hmm... i'm check latest Movica with:
    - FLV with VFR,
    - FLV with FLV1 and VP6F video,
    - FLV with MP3, Nellymoser, PCM and ADPCM (SWF variant) audio.
    Works very good.
    Nov 2002
    Not exactly.
    I went back and looked at the filter thread on the Virtualdub forum and fccHandler started his input filters based on version 1.7.5.
    Somehow I missed versions 1.7.4 and 1.7.5 when they were released (been using the 1.7.3_test releases) but I tried all of the input plugins in versions from 1.7.1 to 1.7.3_test5 and they did not work. They worked fine in 1.7.6 and 1.7.X_5.
    BTW
    Try FLVExtract to demux the video and audio. This worked for me on one file I tried.
    fccHandler says he's fixed the VFR problem with the WMV plugin and from what I can tell, it has corrected the problem with most of my WMV files but there are still a few that will not sync and I have to use TMPGEnc to convert to MPEG.
  12. Originally Posted by DarrellS
    Not exactly.
    Little misunderstanding...
    I'm not 'say' about exist or working plugins before release VD 1.7.4/1.7.5 - i'm say about input driver plugin API in VD.
    Latest VD contain new input driver plugin API.
    Well, of course actual plugins versions not working on old VD builds (crashed or not support).
    BTW
    Sometime worked, sometime not...
    I'm have FLV sample files with VFR.
    When use FLV Extract i'm see: Average FPS 24,67 and Estimated True FPS 29,97.
    FLV Extract save AVI file with Average FPS 24,67 - after mux (and eventually recompress) in VD, desynchro A/V.
    Some other...
    If i'm use FLV Extract (still i'm 'say' about same FLV file) and mux to MKV without timecodes - desynchro A/V.
    But, if i'm use timecodes and mux to MKV - no problem with synchro (FPS is strange).
    However, this MKV it's still VFR - VDM warning message - and of course desynchro A/V (when try change container to AVI or recompress).
    If i'm use Avisynth script or FFmpeg - no problem with A/V synchro.
    Of course, i'm 'say' about only certain FLV's.
