Hi
I convrt my divx files using tmpgenc to mpeg. then, when i cut them, everyhting is ok. but when i try to burn them to cd using easy cd creator 5, i get an error saying that the file is not suitable for VCD/DVD player play becausse of the system clock reference! what is that and how do i make things work. thank u in advance
Wrestling Fan For LIfe
Originally Posted by markdf
Nero writes the size of vcd disk incorrect,you can see this by checking the cd properties in windows explorer.
VCDs' created with nero are only 2-3 Megabytes.
The CD contents and video data are right but checking out windows explorer properties just shows a size between 2 and 3 mb for nero vcds'.
Also nero vcd menus don't work, I mean in many stanalone players.
TMGEnc Xpress - no sound
By deanst2 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jun 2010, 17:27 -
TMGEnc Xpress Not enough memory issue
By hawk123 in forum Video ConversionReplies: 0Last Post: 10th May 2010, 18:21 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 13:19 -
Tmgenc DVD Author
By powerkoala in forum Video ConversionReplies: 10Last Post: 19th Sep 2007, 06:02 -
Tmgenc problem after going "fullscreen to wide"
By spiritgumm in forum Video ConversionReplies: 0Last Post: 21st May 2007, 09:26
