    Nov 2007
    Hello, if anyone knows about Mpeg Layer-3 audio encoding for avi files. The only options i have is 24000hz up to 80 kbps...
    I've tried every codec
    Lame ACM 3.97
    Fraunhofer and the Radium pro version
    Stinky's
    None of them will work. when Lame is installed it will give up to 24000hz 160kbps
    I'm trying to get all the options up to 48000hz. and have tried everything. I also have klite codec and ffdshow. I've tried installing in different orders of each program. Before I reformated the hard drive everthing was perfect
    Apr 2004
    Miskatonic U
    What software are you trying to use ?
    LAME ACM with virtualdub will give you 48kHz up to 320 kbps
    Read my blog here.
    Nov 2007
    I'm using Cyberlink Power Director..
    Thanks...Adam
    Apr 2004
    Miskatonic U
    Did you install LAME, or just unzip it ?
    Read my blog here.
    Nov 2007
    I installed it. Under the encoding options, the option changed from mpeg Layer 3 to Lame mpeg, but still 24000hz
    Nov 2007
    I just installed it again, You have to right mouse click on the inf file and select install.. I did that and now I have many 24000hz options up to 160kbps
    Apr 2004
    Miskatonic U
    The way you are selecting the options, or something in cyberlink in restricting what you see. You should see up 48kHz @ 320 kbps
    Read my blog here.
    Nov 2007
    I just found out it's the newer version of Power Director... I installed the older version that came with my capture card, and now all the options are there....Thanks....Adam
