I Right clicked on video clips on my hard disc and then clicked send to CD-R and then open cd-rom and clicked write these files to CD. All files now could be played on computer's CD drive but not on dvd player.
I used nero--to burn a video cd but the CD burnt contained different folders onlly and nothing could be palyed even on Computer's CD drive.
Can someone tell me a method by which CD can be played on DVD player too? thanks
video on cd - you need to be more specific. there are many formats that can play on some dvd players. divx, vcd, svcd, miniDVD, etc. you need to find out what your player can handle first.
the disc created by nero was probably vcd.
there is not much chance of a cd playing if you right click and copy to.--
You have two choices.
1, Convert to the VCD standard format. This is a low resolution, low bitrate video format compatible with most (all ?) DVD players. You can fit 74 - 80 minutes per disc. Nero can do this for you.
2. If you have a Divx certified or mpeg4 capable player, and your video clips are Divx/Xvid encoded in the avi or Divx container, you can burn these to a CD as data, and they will be playable using the basic menu built into the player.Read my blog here.
Video stutters when deinterlaced an when played in a DVD player
By Kado in forum Video ConversionReplies: 17Last Post: 13th Aug 2010, 12:03 -
Canon T1i video to a dvd to be played in a blu ray player
By jprime84 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2010, 22:23 -
Edges of video cut off when played on DVD player. HELP
By natrap in forum Authoring (DVD)Replies: 8Last Post: 21st Dec 2008, 22:23 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
how to capture video played by Flash Player?
By ktnwin in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2007, 16:40
