I'm looking for a software that can edit dvd (remove unwanted sequence, extras, etc.) and don't need the movie to be encode after it.
Can DVD rebuilder can do this ?
So just throw me some names that allow edit w/ reencoding
Thks a lot in advance !
	The full version of DVD Rebuilder can remove unwanted extras but VobBlanker is much more eficient at doing that.Originally Posted by Kev90
 It has less to do with the program used than with the size of the basic movie. If it is greater than 4.43GB then you will have to at least transcode if not re-encode.Originally Posted by Kev90
 BTW if we are talking about a commercial DVD, this should be in the DVD backup forum rather than video editing.
	ntscuser : it's for a DVD that been already encoded has a DVD5 (4.37gb). But it still remains some extras and trailers. special features on dvd, ect ... that i would like to remove. As the quality has already been reduced, I dont want to do it again.
 guns1inger : Yes, it's about removing things like trailers, extras and specials features on the DVD.
 Thks a lot in advance guys !
	Then use VobBlanker.Originally Posted by Kev90
 To disable unused menu buttons you need PGCedit. The latter can also be used to skip extras without physically removing them but this may cause startup problems on some players.
 Alternatively you could use DVD Shrink in re-author mode to strip everything except the main movie without having to re-encode.
  DVD with several titles: reauthor into 1 title. no reencodingBy elAIalCUETE in forum Authoring (DVD)Replies: 4Last Post: 9th Dec 2011, 06:31
  16:9 DVD video - how to get the original format without reencoding?By Weef in forum RestorationReplies: 6Last Post: 22nd Sep 2009, 09:33
  How can i creade a Dvd video from camera files w/o reencoding them?By junglemike in forum Authoring (DVD)Replies: 6Last Post: 7th Apr 2009, 20:41
  need help in choosing a format after video edit (DV then edit then DVD)By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13
  Help:How to author 3 disc vcd movie into single dvd without reencodingBy devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 04:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
