  1. I have use DVD2SVCD to encode a movie. I choose the right track to encode (1h 37min 12 sec) And now when i looked on the mpg file i has a trailer in the mpg file, and after that the movie starts...how can this be?
    Regards Abel
  2. do you mean you try riping the dvd with dvdsvcd ?? i need more info to help you out cause i used that program now with no problems
  3. I have alredy ripped the movie with smartripper. So i have the vbo and ifo files on my harddrive. The movie is Exit wounds.
    Would be glad if you could help me with this problem.
    Regards Abel
  4. well if you got the vbo files used DVD2avi is easy to used load the vbo file in the program try it
  5. I dont understan what you mean. But i open the .ifo file in DVD2SVCD and then select the movie track 1h 37mini 12sec.
    Abel
    Feb 2001
    England
    Mmmmm..
    My mate had the same trouble with Romeo must die, except the audio started from the movie beginning but the video started from 2 trailers before the actual movie....so one massive out of sync movie even though we selected the correct time track.
    What we did was get DVD2SVCD to re-rip the way it wants by turning on internal ripping and pointing it to the ripped smartripper VOBS.
    It then went off and re-ripped the vobs (Make sure u got enough hardrive space again) Worked ok then for some reason.
    Hope thats of use...
    G
  7. Thanks for the tip! I'll try that.
    Abel
