Hi all,
Just joined, but have gleaned some good hints/advice for a little while now.
Just got a DVD off a torrent (). It contains 5 .avi files (one of which is the menu), a .idx file and a .sub file.
Question: How do I get this back to a DVD playable in a commercial DVD player/TV?
What I've tried:
- Using Toast Titanium 8.0 to make a DVD-Video and Video CD resulted in a non-playable DVD.
Any ideas out there Gurus? Surely people have come across this.
Noddy
Does the burned dvd-video work on you computer? and not your standalone dvd? Then I would guess it's a media problem, be sure to use gooood media www.nomorecoasters.com www.videohelp.com/dvdmedia
The media I use has been successful on all other occasions, so I don't think that's it. Last night I managed to get one done as a SVCD and another as a VCD, but using Toast Titanium 6 instead of my usual version 8. Yeah, it's a compromise but it works.
My next problem was a US region DVD. I got it as a .avi and only VLC would play it. So with ffmpeg I converted it to a .mov, which Quicktime played fine. I then used iDVD to make a DVD of it. Preview in iDVD looks fine as well. Burn the thing and watch it on my standalone DVD player on TV and the whole picture is cropped. Not greatly but it is missing all the outside edges. Any ideas?? Maybe 16:9 instead of 4:3? Maybe leave it as NTSC because I changed it to PAL (not that I needed to as DVD player plays both)?
Nod -
first, what was the codec needed for the .avi to play?
with Perian 1.0 installed, there hasn't been any .avi
I couldn't play in Quicktime withoutthe need of
converting to .mov first.
with Perian installed, you could've just drag/dropped this into
Toast 8, and got a compliant DVD that would have been 24fps,
and your DVD player would have handled it.
Sending it to iDVD is probably what hosed it for sure.
Possibly your 3:2 pulldown flag wasn't set, possibly your
settings in iDVD fo rit to convert it to NTSC...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 17:49 -
Hi8/Video8 to DVD...to editable format...back to a DVD with a menu!
By lornarose in forum Authoring (DVD)Replies: 14Last Post: 8th Nov 2008, 17:03 -
How do I edit DVD-Video and place back into the authored DVD w/o errors?
By Stealth3si in forum EditingReplies: 3Last Post: 12th Sep 2008, 06:48 -
Mpeg Video Wizard DVD: Burned to DVD-R, Plays back with hiccups.
By Giovannini in forum Newbie / General discussionsReplies: 13Last Post: 27th May 2007, 06:54
