Video: XVID 1440x1080 25.00fps 6527Kbps [Video 0]
MPEG4 Modifier shows pixel AR at 4:3
This translates to 16:9 and used to play as 16:9 in MPC
I messed around with MPC setting dealing with MP4 files lately and now it plays it back at 4:3. Any hint on what setting am I missing?
Thanks!
	1440 x 1080 is in fact the squeezed version of 1920 x 1080 (16:9 DAR). If this was set correctly in the file itself, mpeg4 modifier should show it as being 16:9. Of course, this assumes it has been encoded correctly in the first place. Read my blog here.
	MPEG4 Modifier is showing Custom Pixel AR of 4:3. My understanding is that DAR is mostly ignored but pixel AR is honored by some programs.
 It worked in MPC before. It must be something tweaks that I did.
 What's the way to reset MPC settings?
 Thanks!
	I have 2 files, which is split by VirtualDub. The first file is small and plays in MPC as 16:9. The 2nd is large and plays as 4:3. I can't tell any difference. What should I look for?
	OK. I've narrowed down the problem. When there is .srt subtitle file, the avi is played back as 4:3. If I remove the srt file, it plays back 16:9.
 What's going on here?
 Thanks!
	cheerful wrote:
 I don't know.OK. I've narrowed down the problem. When there is .srt subtitle file,
 What's going on here? Anyway, ... Anyway, ...
 In MPC: menu "View", item "Video Frame",
 options = "Keep Aspect Ratio", "Override Aspect Ratio".
  DV footage auto aspect correction in MPC.By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Sep 2010, 09:55
  MPC Aspect Ratio and DVD MenuBy Bardiche in forum Software PlayingReplies: 1Last Post: 12th Sep 2009, 00:25
  MPC fullscreen aspect ratioBy quzma in forum Software PlayingReplies: 0Last Post: 8th Jan 2009, 14:17
  Vobsub messes up aspect ratio in MPCBy cheerful in forum Software PlayingReplies: 0Last Post: 2nd Dec 2007, 12:04
  Aspect ratioBy Digiface in forum Software PlayingReplies: 2Last Post: 24th Aug 2007, 13:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
